Oil Filter ??
  • dwracing
    • 20
    Oil Filter ??
    What type of oil filter should i use for my 2300 cc mini stock mustang?
    "If you ain't first your last"
  • racer#10
    • Feb 2010
    • 25
    we use a motorcraft FL 1A
    • Dirtman29
      • 1690
      NAPA gold 1515.
      • supertruck
        • Apr 2009
        • 174
        oil filter
        I use Wix. tried Fram and noticed a drop in oil pressure.
        • Tenacious55
          • Feb 2009
          • 230
          wix 51515r
          I won the race....even though I finished 12th....Who am I ?
          (2010 Topless 100)
          I'll give you a hint he's a vulnerable adult.
          One of his nicknames is Santa Claus... Because I give so many gifts(wins).
          Give up..... Scott Bloomquist
          • return to dirt
            • 1008
            i use Motorcraft FL1-HP or NAPA Gold(WIX). i also use them on my toyota 20r/22r combo.
            olin
            • dwracing
              • 20
              Thank you all for the advice.
              One more question what is a good transmisson for a mini stock mustang.
              • car62
                • 1579
                51515r
                or
                185515
                www.raceidaho.com
                • Headhunter
                  • 1338
                  Depends on what you need for a final drive will make the choice for the transmission and rear end gears. How big of a track and how much RPM you want to turn the motor are what is needed to determine that. There is no best transmission just the best one for what you need.
                  • dwracing
                    • 20
                    oil filter
                    Thank you i will check in on that.
                    • checkeredflag2006
                      • Jan 2009
                      • 212
                      had brand new mc FL 1A blow apart at the seam sunday!!! anybody had this happen before??
                      • return to dirt
                        • 1008
                        that's why i said to use an FL1-HP. it can hold up to high pressure. what is your pressure?
                        olin
                        • dwracing
                          • 20
                          What Brand of oil should i run?
                          • Dirtman29
                            • 1690
                            I run regular 10W40 pennzoil, 5 qt. jug @ walmart usually about $13. Quaker State is good too, I get that @ menards when its on sale for $1.99/qt. Add a bottle of STP oil treatment, change every 4-5 nites. Been doing this for 5 yrs & never had any problems.
                            • Tenacious55
                              • Feb 2009
                              • 230
                              for a ford 2.3 are you kidding me you use 10W40....and you don't float your valves....wow are you racing in the winter
                              Rotella 15w40 if your running on a 3/8
                              Valvoline 20w50 that has zinc added into it...for those really hot days, bigger track or a lot of laps
                              I don't care what people say any additives will change the viscosity of the oil to who knows what
                              (2010 Topless 100)
