honda rod set up for 2.3
  • leeboy01
    • Oct 2008
    • 24
    Is it worth the money or is it a waste of time
  • soonersublime
    • Jan 2008
    • 995
    Not with a stock crank no. Maybe a forged or billet crank but then your really getting into some money there. I would say if your already askin if it's worth the money then it's more than you want to spend.
    • dirtdemon#4
      • Dec 2010
      • 14
      just go with a set of ford escort rods if you want a light rod engine.also these can work very well if you use the 2.3 stock crank or if you want a lighter crank also use a 1.9l escort crank.also you MUST use arp rod bolts these little engines built like this is worlds worst to brake a rod bolt.and arp is just alott better bolt
      • 84Dave
        • 915
        LeeBoy...... you do not indicate the degree of proposed modification of your 2.3 engine. But let's assume it'll be a full-tilt boogie race engine with a stout crank and close to 8800 rpm at the top end. A 1.999" diameter rod-journal on the crank would allow the use of a good, small-journal Chev V-8 rod, ordered with the proper big-end width, and would 'live' (bearing speed considerations) @ the above rpm & a bit beyond. But the big mistake many of us have made, & many today still make? Whether a cap-screw rod-bolt or thru-bolt with a nut, do NOT use a torque value to tighten/clamp the rod. Use the recommended bolt-stretch value & note the torque value to get that stretch value. Spend $55 and purchase a decent rod-bolt stretch-gauge from JEG's catalog. ARP will tell you, if you use their cap-screw/bolt, to clamp the rod up in your bench vice & 'cycle' their rod bolts @ least (3) times in order to 'burnish' the threads well for an accurate/proper stretch/torque value. For myself, I don't give a rip what the manufacturer recommends for lubrication on the cap-screw/thru-bolt. I always use the ARP moly, in the small packets, to lubricate the threads and the underside of the nut/cap-screw head. Then, with the rod(s) in my bench vice, I 'sneak up' on the final stretch value by torque cycling the fasteners 3-5 times up to that stretch value. With the torque value noted for desired stretch. Then when the rods are installed in the engine, a stretch-gauge is not needed. Simply torque the rods to the value noted for proper stretch from the bench-vice cycling operation. And Crower(I use their Maxi-Lite rods), in no uncertain terms, advised me to NEVER bounce back & forth between rod fasteners. Stretch/torque the bolt in one single, smooth movement! Then go to the other fastener. PLUS...... do NOT use a 'clicker' torque-wrench on rod fasteners. My favorite? A Sears/Roebuck 75# BEAM torque wrench. I have (2) of them hanging on the wall. I had both brand new wrenches calibrated on one of the digital calibration machines, and both were within 1#-2# of torque on the beam indicator. Since doing all the above, I've not hurt/broken a rod/bolt in a race engine! -Dave-
        • leeboy01
          • Oct 2008
          • 24
          84dave
          well i'm going to be running 3/8 mile dirt oval wanting turn between 8500-9000 rpm,
          also has any body ever heard of taking a 2.5 crank and running it with honda rods and making 2650cc is it a reliable set or should i go with a 2.3 crank with honda rods?
          • soonersublime
            • Jan 2008
            • 995
            If you want to turn that many RPM's your probably better off w/ a 2.3 stroke crank rather than a 2.5
            You can take a 2.5 to 8500 but I wouldn't recommend any more than that.
            If you are wanting to build a nice 9000-9500 RPM motor then a good combo IMO
            Forged 2.3 crank - Raceeng
            Custom Billet 5.7 Rods Crower - Raceeng
            Custom CP ultra-light pistons - Raceeng
            Fully ported BoPort ARCA head
            Custom exhaust
            Schneider Custom Cam and valve train.
            This combo can produce 300 HP easy.
            Strap the sucker and get a dang good oiling system.
            • car62
              • 1579
              the big question is...is your cam going to make any power at those rpm's?
              www.raceidaho.com
              • car62
                • 1579
                personally id only run a dry sump at those rpms
                www.raceidaho.com
                • rocket22
                  • Dec 2009
                  • 87
                  what has to be done to run this setup and does it make good power
                  • soonersublime
                    • Jan 2008
                    • 995
                    You can make power easily at this RPM you just have to have a custom cam. You would run something very similar to what the guys run w/ midgets. Def wouldn't run this RPM w/ a wet sump system but if you had to a custom 9 quart pan would probably work.
                    • grydergeyer26
                      • Oct 2008
                      • 168
                      what do u have to do to the 2.3 bolck or to the 1.9 crank and rods? doesnt that destroke the engine?
                      so does running that setup let u run higher rpms? or just rev faster?
                      • oklaministock
                        • 15
                        We have had good luck with johnson machine 5.9 rod motor with there oil pan turn it 8900rpm won many features with this bottom end with a well built head.
