Rear gear
  • JTGibson15
    • Nov 2011
    • 7
    Rear gear
    In Virginia will a 327 gear work in my modified mini or no thank u
  • 84Dave
    • 915
    Will probably work OK in Virginia, but may be less than optimum in Maryland or either of the Carolina's ! -Dave-
    • supertruck
      • Apr 2009
      • 174
      Rear Gear
      Sorry, won't work in Virginia. Something about the air makes a 3.27 gear run in reverse. Now if you install it backwards it's OK.
      • crcltrakr
        • 293
        Rear Gear
        Now now, play nice.....
        Perhaps with a little more information, ie engine/trans ratio size/rpm/track length & type you could get more useful answers....
        JerryM
        • BVS40FL
          • Nov 2008
          • 52
          Experiment
          If you do try a 3:27 and it works.
          You gotta try a 3:31. It's just "a little bit" better.
          That's the hot set-up here in Fla.
          • usedtobefast
            • Dec 2009
            • 83
            3/8 mile track with 2.14 trans. and 327 rear gear works great
            • 84Dave
              • 915
              Easy Rule-of-Thumb to remember. For every .1 FINAL ratio gear change at the rear pavement/dirt, the engine rpm will change 125-150 rpm, up or down. -Dave-
