drop spindles
  • poor boy
    • 41
    drop spindles
    does anyone make a drop spindle for a 85 mustang or any ideas on how to make them
  • crcltrakr
    • 293
    Here's some, but they're pricey.......
    Racecraft : Down for Maintenance - Apparel / Stickers / Banners Electrical Exhaust Fittings Hardware Power Adders Safety Gear Shocks Rear Springs Steering Chassis Tabs & Mnts Fabricated Housings Coil Over Kits 2 Drop Spindles MidPlates MotorPlates GARAGE SALE Axles, 3rd Members & Gear Sets Brakes GIFT CERTIFICATES Tools Wings Struts Dzus Rails A-Arms Shocks Front 1.5 Drop Spindles 8.8 Rear End Housings K-Members Rear Suspension Batteries Body Transmission Acc. Caster Camber Plates Racing Seats / Seat Brackets Lexan Windows Limiter Kits Tube Adapters Lightweight Bolt Kits Suspension Packages Intercooler Grommet Seals Fill Caps Micro Blue Bearings RCI Canopy Weld Racing Wheels Wheel Accessories Shifters & Accessories 3 link suspension, 4 link suspension, axle, axles, brakes, camaro, camaros, camber plate, caster camber plates, chassis, chassis components, chassis engineering, chassis parts, coil over, control arm, control arms, drag chassis, drag racing chassis, drag suspension, drop spindles, exhaust, exhaust system, exhaust systems, exhausts, front suspension, intercooler, k-member, lower control arm, lower control arms, lowering springs, muscle mustangs and fast fords, mustang, mustangs, nitrous, racing, racing chassis, rear axle, rear suspension, rolling chassis, springs, steering, strut, struts, suspension, suspension kits, upper control arm, wings
    JerryM
    • RACEMAN
      • 323
      Speedway. Here's the link.
      http://www.speedwaymotors.com/Mustan...dles,2098.html
      Much cheaper.
      Sorry, not sure if they'll fit an '85.
      • crcltrakr
        • 293
        Believe he was asking for a Fox series, aka Mustang 3, I believe these are the Pinto style used on Mustangs prior to 79.
        JerryM
        • 84Dave
          • 915
          PoorBoy...... or anyone else looking for top-notch spindles for 4-cylinder racing, call Garrett Doyle Performance @ (661)965-9109. He has a special jig he built strictly for spindle construction. Dropped, angle changes, lower/upper arm length changes, steering arm angle/length changes, etc ...... Garrett can do it all. He has manufactured many for our west-coast Pro-4 racing. But he'll likely ask you to send him an example of your current spindle, if you simply want it 'copied', or ask you for desired changes you think you need/desire. He can advise in that area also. Oh....... his e-mail is doylegarrett@aol.com. Tell him Dave Carpenter sent you. -Dave-
