schoenfeld header
  • oldgoat
    • 20
    schoenfeld header
    Which of the 3 would be the best? Running 3/8 mile clay. Stock crank and rod 2.3 with 120 off the head and 350 holley. Turning 7200 rpm. Thanks for any input.
  • 84Dave
    • 915
    What are the specifications of the (3) headers you're looking at? Primary diameter? Primary lengths? Collector diameters?......... etc. -Dave-
    • oldgoat
      • 20
      They are all 1 5/8 to 1 3/4 with 3 inch collector. Schoenfeld #233vy, f235v and f239v.Never ran a header before so am looking for someone to point me in the right direction. Thanks again
      • Doug_Guilds
        • 170
        Well I looked up the 3 headers just for fun, and the #233 is a tri-Y design through the firewall style. The #235 is a 4-1 through the firewall design, and the #239 is a 4-1 conventional under car exit style. They all have the same primaries and collector. 1 5/8- 13/4 primaries with an 8 in long 3in diameter collector.
        The real question here is are the tri-y headers worth the extra 200$ and what preference you have as far a the header routing. Maybe some of the dyno guys can chime in on the tri-y vs the 4-1 headers.
        • return to dirt
          • 1008
          i have all 3 of those headers plus the shoenfeld 11/2-15/8 tru the firewall and an old rob header. no dyno, just seat of the pants and results. my opinion, for anything from 7200 up i run the old rob header, no contest. anything below that i run the tri-y or the 11/2-15/8. this again is not per any dyno just how it feels and performs. i have ran all of them in my mustang and all but the tri-y in my pinto(it won't fit with the setup i have). for your use and the money i would find the 11/2-15/8 unit.
          olin
          • car62
            • 1579
            id check out the nice piece at www.powerbyace.com
            www.raceidaho.com
