Have a '93 twin plug head. I understand the flow numbers are pretty good. Question is, can these things be adapted to run as a single plug with conventional distributor etc for mini stock race purposes without spending huge sums of money?
Twin plug 2300 head
Dual Plug Head
Everything is interchangeable except the intake manifold,dual plugs heads bolt right on the older blocks and vice versa.Cams etc all swappable.Biggest issue is no readily adaptable carb intakes.
You can of course just fire 1 set of plugs.
Newer heads have 7mm valvestems and round tooth timing componants which are a plus.
Limitations to milling are the same as single plug heads,you can cut right down to the intake bolts.
We have had good success running them with an .080- cut and Esslinger SVO intakes redrilled to fit and some porting on the intake side.
Stock porting has a great deal of swirl,too much for a high rpm race head IMHO. Without some port work they will not flow as well as a stock oval or d-port.
pm me i need help on a twin plug 2.3 thank youOriginally posted by racedad View Posteverything is interchangeable except the intake manifold,dual plugs heads bolt right on the older blocks and vice versa.cams etc all swappable.biggest issue is no readily adaptable carb intakes.you can of course just fire 1 set of plugs.newer heads have 7mm valvestems and round tooth timing componants which are a plus.limitations to milling are the same as single plug heads,you can cut right down to the intake bolts.we have had good success running them with an .080- cut and esslinger svo intakes redrilled to fit and some porting on the intake side. Stock porting has a great deal of swirl,too much for a high rpm race head imho. Without some port work they will not flow as well as a stock oval or d-port.
