2300 ford deck height
  • r3tracing
    • Jul 2011
    • 224
    does anyone know how much pistons can protrude out of the block and still be ok. this is a steel rod 5.2 length motor.
  • let-r-eat
    • 2319
    Alot depending on the head gasket thickness. With a standard .042 Felpro 8993 gasket around .010.
    BUCKLE UP NOW, YA HEAR?
    • r3tracing
      • Jul 2011
      • 224
      So .013 or .014 would probably be too much with the 8993 gasket
      • car62
        • 1579
        how much is milled off the head?
        www.raceidaho.com
        • r3tracing
          • Jul 2011
          • 224
          Don't remember for sure. We changed rods from stock to crower 5.2 and now they protrude farther than I was hoping. It was at zero with stock rods. Just concerned about the pistons smacking the head
          • 84Dave
            • 915
            What rpm do you intend to buzz the engine? If you're going to spin it 6500+, probably should have a bare-bones minimum of .030". And check/measure, at the outer circumference, how much the piston 'rocks' @ TDC. With a marginal piston-head clearance, piston rock/clearance can be a problem on the cam overlap cycle. PLUS...... if the clearance is marginal, quench 'pump' can suffer & cost you some minor TQ/HP. You want the burn pattern clear across the top of the piston. If in doubt, 'dimples' in the piston crowns will help. -Dave-
            • r3tracing
              • Jul 2011
              • 224
              Thanks for all the info. We cut top of pistons about .010 and we should be good now. This motor should see about 8000 so we wanted to be safe
              • Racedad
                • 340
                We have run .027 Cometics with 0 deck on a 2.5 with stock pistons.No signs of contact at 7600.I built a 305 Chev back in the day with 0 deck and .017 steel shim head gaskets.That car ran like a shaved ape but the pistons were hitting the heads some. That was too close but it never broke........
                I know some ofeS this is waaaay out there and flame away but here are some things I like about a minimum squish clearance:
                Running on the tight side I think you get awesome turbulance and so are less likely to suffer detonation damage under extreme conditions.
                The piston slows dramatically near TDC so if you cross the line and get contact at high RPM it's not as violent as you might think.
                I also think MAYBE under extreme over-rev that we get protection from rod cap/rod bolt stretch with a tight piston-head clearance at TDC. Especially now with low tension rings.I don't have the rod and rod bolt failures I used to have since I have been building tighter side squish but that is also probably due to less detonation.
