I just bought a mazda b2000 pickup to build into a race truck. Any thoughts or suggestions? I don't want to hear "that was a bad idea." I will make it work, and I will make it competitive.
Anyone ever build a mazda?
Had a couple of Mazdas running at my track in past years, they had the 2300 Ford motors and were very quick. Truck is lighter than the S10 and Ranger and they ran up front most races.
Mazda truck
Have 2-3 guys at evans mills running mazda trucks.One of them ran with us at Bethel and Shang.They run pretty good,two are 2200,s and one is a 2600.The 2600 has won a few races and all of them run in the top 10 most weeks.Easy to adjust with the torsion bars.Need to watch out for rusted frames and bar mounts.Flatlander racing has some good engine kits and as stated,Allison series
What motor are you planning to use? I had a difficult time finding parts when I rebuilt my dads 1.8L and it was a stock re-build. I think there are more parts available for the 2200 motors.
Yes frame rot behind the cab was a big problem with those trucks I had to cut the frame out and added steel and then boxed it all in on both sides and the shackle mounts in the rear I needed to repair also
Newer B2300/b2500 are just rebadged Rangers. With your plans for no intermarraige of engines will you allow a B2000/B2200/B2600(old style Mazda) with a B2300/B2500(actually a Ford)engine???
Better be clear up front with your drivers or I'd build me one of those light old style trucks with Ford power for sure.
The early Courior/Mazda is a Ford I cant see why you cant put a ford in the place of the 1.8 Mazda engine. Seen a lot of guys do it, and they can be very competitive. F ord and mazda have been working together for years.dr6 motorsports
Well, the engine has to be available in that make and model, regardless of year. So the early B-series truck is the same thing as a Courier. So whatever engine I put in it has to have been available in a courier at some point...
^ True that. Both Mazda and Ford have been doing great job in the race track. I just don't know for sure the right build for it but with right details and stuff, you'll get it right.Originally posted by dannyracer6 View PostThe early Courior/Mazda is a Ford I cant see why you cant put a ford in the place of the 1.8 Mazda mats engine. Seen a lot of guys do it, and they can be very competitive. F ord and mazda have been working together for years.Last edited by cswitch11; 07-29-2012, 06:49 AM.
