Air filter
  • Wild Blue 32
    • 90
    Air filter
    Other than the K&N oval air filter what air filters are you guys running on your Ford 2.3s.
  • Dirtman29
    • 1690
    I have run paper filters with no problems, usually a 10" round X 3" tall fram (I THINK its a CA192). Blow the dust out weekly, lasts about 4-5 nites, depending on how dusty track gets.
    • jatchis
      • 328
      We run standard paper 14x3 filters, with Moroso foam pre-filter.
      I don't suffer from insanity ... I enjoy every minute of it!
      http://www.Scalded-Dog-Racing.com
      • Milford Motorsports
        • Jun 2008
        • 285
        We run the KN 14 x 3 round filter with the KN top hat filter on top.Just need to find a base that will clear the valve cover.
        • car62
          • 1579
          your local NAPA..or any parts store for that matter makes an air filter "riser" that goes between carb and filter base to raise it..they come in a 3 pack with 1/4...1/2...and 1 inch spacers for about $7
          www.raceidaho.com
          • jatchis
            • 328
            We get them completely out from under the hood, so we get ambient air, rather than the hotter, under the hood air. We just get a cheap CalCustom, or Mr Gasket velocity stack, cut a 14" base so it has an 8" hole, and rivet it to the top of the velocity stack Seal it up with silicone, and you're good to go.
            • Wild Blue 32
              • 90
              We have to use a stock 5200 holly/weber carb. Is there an air filter housing made to use an aftermarket air filter or do I have to make my own? I would like to run about an 8 to 10 inch filter. Preferably something I can clean.
