repairing a iron head?
  • bentvalve
    • Jan 2012
    • 3
    so basically it looks like someone puched thru on intake runner and fixed it with epoxy.
    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
    would you worry about the reapir and or would you have it welded and reworked..or would you just stay the hell away from it? thanks..don
  • Racedad
    • 340
    Depends.............
    If you don't have to pay much for it or if you already own it and it doesn't need a lot of other work I'd rough up the port an inch around the hold and clean it up with a good solvent.Mix up some JB Weld and fiberglass strands and patch it.
    I've got a head with a spot bigger that that been running it for 5 years.
    Lot of guys have hit water when porting and fixed it with epoxy.
    It's so thin around that hole I don't know how well welding would work.
    • bentvalve
      • Jan 2012
      • 3
      it has all new valvetrain,cam,guides and stage 3 ported. its $400...i am building a 2.3 turbo motor and im not sure i can pass this deal up..don
      • CushionArtist
        • Oct 2008
        • 122
        Ran one with epoxy in it for years. If its a good deal then give it a try.
        • let-r-eat
          • 2319
          That epoxy is eroding and has been in there for a while. On the short turn like like the epoxy is probably filling that whole turn in. There is more epoxy in there than appears. I would mix up some fresh, reshape and give her hell.
          BUCKLE UP NOW, YA HEAR?
