2300 ford cam
  • 123KID
    • 19
    2300 ford cam
    I have been out of mini stock racing for some years looking for some help whats the best HYDRAULIC cam to use now days we have no lift rule just has to be HYDRAULIC any help would be great thanks
  • mustang99
    • Apr 2011
    • 39
    cam
    i get all my stuff from http://racerwalsh.zoovy.com/
    depends on what size track,,,gear ratio,,,just check out the cams they have
    • return to dirt
      • 1008
      try schneider cams. very good cams.
      olin
      • 84Dave
        • 915
        I agree with Olin. Tough to beat Schneider Cams. They've been grinding cams for SOHC Ford 4-cylinders for 30+ years. And for a $50 bill, I'd also recommend DeskTop Dyno 5 @ www.proracingsim.com . Between the dyno engine sim & the cam manufacturer, you should be headed in the right direction regarding cam selection. -Dave-
        • Racedad
          • 340
          Schneider all the way.........
          x3 on Schneider. Whatever cam you choose use the correct and top quality valve springs.
          • 84Dave
            • 915
            If you must use a hydraulic cam, and based on head/engine mod's required for best power......... under your Rules, seriously consider PAC (www.racingsprings.com) NITRIDED beehive springs. I've never failed one over nearly 2 decades. -Dave-
            • car62
              • 1579
              yep...Schneider all the way.
              We have 9 championships using Schneider Cams...Jerry knows his stuff..and stands behind his products.
              www.raceidaho.com
              • dannyracer6
                • 1063
                Eric,
                E Mail me, what to talk to you. Need a cyl. Head.
                Dan
                dr6 motorsports
                • car62
                  • 1579
                  chaney2333@roadrunner.com
                  www.raceidaho.com
