Transmission HELP???
  • dwracing
    • 20
    How do you find the gear ratio in your transmission?
    "If you ain't first your last"
  • Dirtman29
    • 1690
    Should be a tag on it somewhere, that tag has the factory codes to identify your trans. Do you know if its 3,4,or 5 speed?
    Find those codes & then go to breezemans site, there you will find all ford transmissions & gear ratios.
    • dirtdobber71
      • Mar 2012
      • 2
      I have the same problem. What about 80 ET BA? didn't see that one on there.
      • Dirtman29
        • 1690
        Look at the tag again, there is more than one code on it. My T5 tags have a few codes, I needed the code 1357-XXX to find my ratios. Need to know 3,4, or 5 speed.
        • oldracing2
          • 22
          Ratio
          If yours does not have the tag like probably 50% of the trannys used in racing , mark the input shaft and the output shaft. Put tranny in the gear you needing to know, have some one help by turning the output shaft one complete revolution, while you count the revolutions the input shaft turns. Now divide the larger number into the smaller number and this will get you in the ballpark.
          • dirtdobber71
            • Mar 2012
            • 2
            Mine is a 4 speed,
            the tag reads:
            80 EI BA
            FOG 9J 07G
            On the case by the cover it has:
            77ET
            7006AA.
            still don't see either one. I turned the output and I got about 3 teeth past 2 turns on input shaft, but be nice to have the exact ratio.
            • dwracing
              • 20
              It's a 4 speed and thanks for everybodys input.
              • crazyhorse
                • 430
                77et aa is 2.14 second gear
                • crazyhorse
                  • 430
                  dw--on the drivers side of the main case by the top cover are some more numbers--tell us what they are.
