T5 tranny
  • supertruck
    • Apr 2009
    • 174
    T5 tranny
    I know nothing about transmission internals so this may be way off base. I run my T-5 in 2nd gear. Is it possible, or worthwhile, to remove 3rd, 4th, and 5th to save weight and rotating mass?
  • oldracing2
    • 22
    T5
    You would drop off on your RPMs more than likely, but just for the fun of it at practice give it a try. Don't know your track size or the ratio's you are running. Prehaps you could let us know this info.
    • return to dirt
      • 1008
      it depends. if you lose every race by a half car length then it is worth a try. if you lose every race by a half a lap then there are other areas to improve on before you worry about the little things. you can remove unneeded parts from the trans but there are a lot of areas to make bigger improvements in.
      olin
      • supertruck
        • Apr 2009
        • 174
        T5 tranny
        return to dirt, you're absolutely right. Thanks for the input.
        • 96MiniTruck
          • 69
          In my experience at Langley, the best results will be obtained from a good setup and rolling through the corners well.
