anybody had a problem with a fox body getting tight when the track gets really dry. springs are 600 rf 500 lf 175 rr 200 lr. afco rear shocks .
How much tire stagger (front & rear)?Originally posted by r3tracing View Postanybody had a problem with a fox body getting tight when the track gets really dry. springs are 600 rf 500 lf 175 rr 200 lr. afco rear shocks .
RF brake on?
Air pressures?
I usually have the opposite problem when track gets dry, car gets loose.
thats usually the problem but my 12 year old is driving it and keeps saying it gets tight in the feature but good in heat. all of the tires are the same size, track dictates that. he says he isnt touching the brakes just letting off throttle. air is 21 rf 18 rr 12 lr 12 lf. was wondering if we should swap rear springs but it is hard to get much info from a 12 year old but he tries really hard.
wheel spacing will helpOriginally posted by r3tracing View Postthats usually the problem but my 12 year old is driving it and keeps saying it gets tight in the feature but good in heat. all of the tires are the same size, track dictates that. he says he isnt touching the brakes just letting off throttle. air is 21 rf 18 rr 12 lr 12 lf. was wondering if we should swap rear springs but it is hard to get much info from a 12 year old but he tries really hard.
Sounds like the 12 psi in the lefts is too low (to me). I run 20 RF, 17 LF, 17 RR & 15 LR for features. Like I said, its loose but still driveable. My RR has gained up to 3 psi in a feature, 2 psi in the LR, but starting with too low psi (in RR) can cause the tire to pop off the bead (been there done that!)Originally posted by r3tracing View Postthats usually the problem but my 12 year old is driving it and keeps saying it gets tight in the feature but good in heat. all of the tires are the same size, track dictates that. he says he isnt touching the brakes just letting off throttle. air is 21 rf 18 rr 12 lr 12 lf. was wondering if we should swap rear springs but it is hard to get much info from a 12 year old but he tries really hard.
You would be amazed at how much difference an extra 1/2 to 1 pound of pressure in the right rear will loosen a car up when the track goes dry slick.
i had the same problem,,,here is what i do....i unhooked the right front brake,just run the left front and back brakes.just before i go into the turn i hit the brakes somewhat hard to set the car up in the turn,,when u hit the brakes it brings the back end around just enough to get it to turn.might not work for u but this how i do it.Originally posted by r3tracing View Postanybody had a problem with a fox body getting tight when the track gets really dry. springs are 600 rf 500 lf 175 rr 200 lr. afco rear shocks .
I do the same thing, people claim its not safe (3 wheel brakes) but my car still stops just fine.Originally posted by mustang99 View Posti had the same problem,,,here is what i do....i unhooked the right front brake,just run the left front and back brakes.just before i go into the turn i hit the brakes somewhat hard to set the car up in the turn,,when u hit the brakes it brings the back end around just enough to get it to turn.might not work for u but this how i do it.
also put a zip tie around your right front strut and right rear shock , before you go on track slide them to where they touch body of strut and shock! check them when he comes back of track to make sure car is not bottoming out !it will show you the roll in car!Originally posted by r3tracing View Postwe have a practice this weekend we will give it a try.
