fuel cell in mustang
  • snsracing18
    • 5
    Can anyone tell me how to run the fuel lines for a 87 Mustang? Is fuel injected right now but I might swap it over to carb
  • Dirtman29
    • 1690
    Swap it to carb, the 2.3L OEM EFI is garbage for racing IMO. Then run your fuel line from the cell straight to a mech. fuel pump (make sure your aux. shaft has the lobe on it to work the pump). Some early EFI engines have a lobe, some dont. Then out the pump, thru a filter & up to the carb. Mine is all 5/16" line. Hope this helps.
    • snsracing18
      • 5
      Thanks I appreciate it that does help alot il start pulling it today it
