Blew my second 2.3L ford engine. Gonna find a block to but everything back on, head is in good shape. Trying to do this on the low budget side so need some quick thoughts:
1) Any significant benefit of not using stock crank shaft? If yes, what is an inexpensive one to use?
2) What harmonic balancer and water pump pulleys should I use an where can I get a set?
3) Where can I find a serpentine belt (not running any other pulleys other than two mentioned above?
4) Can't stroke the engine (maximum bore an stroke are :Bore-3.841 Stroke -3.126) or have domed pistons, so what other modifications do you guys suggest?
5) Flywheel suggestions?
6) All other suggestion accepted and appreciated....
I run at Dixie Speedway in Woodstock, Ga. Use the link below in your browser to see the rules.
