Im wondering where other people check there ride heights on a mustang chassis I've been checking mine from the center of the bolt that holds the lca front and rear. I'm just curious what everyone else is doing and how high most people set the frame.
Mustang ride heights
not trying to sound rude,but since the bolt is a PIVOT for the control arm,how effective do you think your way really is?No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
The front bolt the goes thru the frame. I would think it would only change with the ride heights. My car has the frame rails tied together and I can measure from the frame rails but I'm helping a man set up a car and his is still a uni-body car and I don't trust the floor board to be in the right location on a car that's took a couple licks. What do you use car62?
i go by what the shocks tell me using travel indicators,in our class were allowed a 4" ride height measured at LF without driver...lowest point of the car is the unibody "frame" rails under the front where it contours the firewall/floorpanNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
if the car has taken licks like that you might be wasting your time !! frame rails is where we set all of ours!!Originally posted by faster12 View PostThe front bolt the goes thru the frame. I would think it would only change with the ride heights. My car has the frame rails tied together and I can measure from the frame rails but I'm helping a man set up a car and his is still a uni-body car and I don't trust the floor board to be in the right location on a car that's took a couple licks. What do you use car62?
