What size master cylinder?
  • Doug_Guilds
    • 170
    I am planning on redoing my brake system on my Mustang, and am thinking of going with a new after market master cylinder. I see there are 3 different bore sizes (3/4, 7/8 and 1in) and am wondering which would be best for my application.
    The car is 2300lbs and I am currently running 3 wheel brakes with the power brake MC and no booster. I may go back to 4 wheel brakes if I don't like the feel of the 3 wheel.
  • car62
    • 1579
    id go with 7/8 up front and 3/4 in rear
    www.raceidaho.com
    • Dirtman29
      • 1690
      I use the same setup as you, 4 wheel brakes will tighten the car going in to the turns. Never had a RF brake, never will! I wouldnt mess with it (IF the car handles the way it is setup now).
      • car62
        • 1579
        i guess it may be different on dirt...
        either way id run twin MC's with a balance bar.
        www.raceidaho.com
