There was a page on the web at one time that listed all the ford transmission gear ratios. I think it was "Boreman" or something similar. Can't find it now. Anyone know of the web-site? I figure Dodge22 if you're still around will.
Transmission info
Transmission info
Remember to bring a friend or four when going to the track!
Have Fun, Go Fast, Be SAFE !!Tags: None
Thanks crcltrakr. I hadn't used it in a long time and forgot the correct name. But hey, I didi have the correct 1st letter. thanks again.Remember to bring a friend or four when going to the track!
There is also a chart of final drive ratios on the earlier transmissions located in the
technical section at www.powerbyace.com I believe you can download it in excel and
add your own ratios.
Thanks Rob. I had both of these but had a comp crash a while back. Think I'll print both out so I don't lose em.Remember to bring a friend or four when going to the track!
