Hyd. to solid lifters
  • oldgoat2
    • Apr 2012
    • 4
    2.3 with 450 lift hyd. cam. If I just change to solid lifters will it perform the same or will it hurt performance?
  • crcltrakr
    • 293
    Perform the same or hurt performance?
    Interesting Question.
    For no gain, why Bother.
    Some cams claim to be able to be run as either, but unless the accel/decel ramps are appropriate, the results won't be exciting. A purpose ground solid cam with the proper geometry and springs will give the best results.
    Theoretically a solid lift cam will rev higher and allow a more agressive profile. The optimum, in my opinion, is a proper aftermarket roller cam set-up.
    JerryM
