Pinto rear springs
  • russ5499
    • Nov 2008
    • 106
    Pinto rear springs
    I've heard that rear leaf springs give up after so many races. Should they be replaced periodically? the car runs on a 4/10 and 3/8 mile mild bank clay track. The 4/10 track has been fairly smooth, 3/8 very rough and wet. right now it has afco 159# R.R. 138# L.R. Also any opinions or advice of afco vs landrum
    http://www.geneseestamp.com/
  • let-r-eat
    • 2319
    Both are basically the same. A leaf spring looses its arch when it becomes weak. Here is a link to show what I'm speaking of:http://www.hotrodhotline.com/md/html/spring_basics.php Look down where it says free arch. Determine what the arch should be on the ones you have. I couldn't tell ya what they should be, maybe call who made them?If the race car is maintaining the ride heights then you are fine.
    BUCKLE UP NOW, YA HEAR?
    • crcltrakr
      • 293
      rear leafs
      The loss of arch is the key indicator, keeo up with it and re-arch as neccessary, you must have sufficient arch and spring rate to prevent going reverse arc under dynamic loading.
      Cold rolling will restore the arch.
      JerryM
