Motorcraft Carb Question
  • car62
    • 1579
    i saw awhile back there was a chart posted,i have tried the search function and came up empty handed...there was a CFM chart for these carbs..i have about 15 carbs and id like to write down what the CFM is on them,they range from 1.08 to 1.33
    www.raceidaho.com
  • car62
    • 1579
    Actually i just found the chart.
    0.98 = 190 CFM
    1.01 = 240 CFM
    1.02 = 245 CFM
    1.08 = 287 CFM
    1.14 = 300 CFM
    1.21 = 351 CFM
    1.23 = 356 CFM
    1.33 = 424 CFM
    www.raceidaho.com
    • dougskewl
      • Nov 2011
      • 14
      Cool that you found it but good info for the rest of us
      • 2old2nobetter
        • Jun 2012
        • 3
        WE had real good luck with the 1.21. Drill the jets to what you need take chock off.And hammer down!
        • return to dirt
          • 1008
          those numbers are pretty close. i flow tested a 1.33 a few years ago and it flowed 422 cfm with the choke plate still in the carb.
          olin
          • Dirtman29
            • 1690
            Ive used the "121" carb for 5 yrs. now, works better than the holley I used to use. Still has stock 53 jets in it.
