I need to know where to find a lower radiator hose that has the wire cone in the center. Where can I find one or what is a manufacturer and part # so I can find online? Thanks.
radiator hose ford 2.3l
Go to your local Napa store.We have never had a problem with their hoses.Most are usually under $20.00
Or...... if you have a tube bender in your area, bend a section of tubing to fit the lower hose profile from the radiator to the input of the water pump. Then use a short section of hose on each end to hook it up. In that manner, guaranteed the lower radiator hose will not collapse. -Dave-
