Roller followers
  • TR32
    • 15
    Roller followers
    Dumb question time.
    Can you use roller followers on a non- roller cam?
  • car62
    • 1579
    no,the cam is too soft
    www.raceidaho.com
    • 84Dave
      • 915
      Eric....... I do not agree. But one must watch what they're doing if a roller-follower is used on a flat-follower cam. TR32....... If you have David Vizard's book, 'How To Modify Ford SOHC Engines'(ISBN 0 86343 0856), go to page 55 under 'Roller Followers'. Vizard spells out very well what to expect if a roller-follower is used on a flat-follower cam. -Dave-
      • 14flower
        • Mar 2010
        • 262
        just make sure u have flat tappet spring presures installed and open. most guys forget about open pressures ive ran it befor with no problems. just remember that one has a 1.65 rocker ratio and the other is a 1.80 ratio
        jared flower
        • millerlt3
          • 96
          They dont recommend that you run roller rockers with cast cams because of the difference in rockwell hardness between the heat treated and ground roller and the cast cams. in my opinion if you really want to run roller followers run a roller cam.
          Miller
          • 14flower
            • Mar 2010
            • 262
            when i ran roller rockers on a flat tappet it was always on a lunati cam. never had a problem
            jared flower
