need a new wide belt for esslinger pulleys what fits it ???
  • pilotracer
    • 160
  • car62
    • 1579
    1994 Taurus SHO belt...as long as you have the wide pulleys...same belt at about $50 less than what Esslinger sells you 1 for..i think the belt is $22.99 at Auto Zone and $75 at Esslinger
    www.raceidaho.com
    • BMDriver
      • Jul 2012
      • 1
      So how did you come up with this - have you actually tried it?
      According to the Autozone website it shows that the tooth pitch of the belt is different (0.31496 on the SHO and 0.375 on a standard 2.3) Ok maybe is 0.060" close enough, but wouldn't the extra teeth on the belt - 155 on the SHO and 129 on the standard 2.3 belt be an issue.
      • car62
        • 1579
        if you have the wide pullies as a said,you will see they have a different tooth count than the standard esslinger pullies
        www.raceidaho.com
        • let-r-eat
          • 2319
          The ultra wide is 155. Do you have round or square teeth? Either way you can use a factory belt. Factory square tooth or the round tooth ranger/mustang depending on what you have.
          BUCKLE UP NOW, YA HEAR?
          • car62
            • 1579
            the ultra wide is round
            www.raceidaho.com
            • pilotracer
              • 160
              read
              92 tarus sho belt works perfect for esslinger wide belt and it was only 2399 compaired to 75 at esslinger
