Pulled carb and noticed large amount of oil in intake runner #1 which appears to be being pulled down the other runners. Have removed head, replaced valve seals, cleaned entire head and replaced head only to find same problem one week later. Ne one have ne suggestions?
Oil inside Intake
Were the valve guides tight ? A worn guide could cause this problem.If you are running a .580 or larger cam make sure the bottom of the retainer is not touching the top of the valve seal when the valve is at max lift.Have seen this problem often lately,guys replace cam with higher lift cam without remachining head for new parts.
Valve guides seemed tight when we had it apart but that is currently one of my thoughts. My other thought was maybe a cracked head? It was magnafluxed in april and was fine but problem just started last few weeks. I am not running a pcv system just a breather in top of valve cover.
I was wondering about rings but compression is good and even across all cylinders and car doesnt smoke even the slightest amount and Exhaust ports r spotless. You would think car should smoke or at least huff smoke under acceleration right? Oil definitly is originating from cylinder #1 just not sure if its from the lower end or head.
is it oil...or is it more of a black carbon?No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
is it possible you used too long of a bolt to bolt the intake to the head(front/top)and cracked the threaded boss?No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
