Dorton Carb Question
  • car62
    • 1579
    so 1 of the discharge nozzles( i think thats what its called,the 2 things that stick out above the butterflies when you look down a carb) broke and was sitting on the butterfly...i took the carb apart and it looks like they(and all holley carbs)put the nozzle in and then flare the end so they cannot come out....anyways...anyone know where to send the carb to have it repaired?
    www.raceidaho.com
  • Buckle
    • May 2008
    • 20
    How about BLP?
    I had good luck last year with BLP Racing Products (407-422-0394) when a discharge nozzle screw stripped out the threads on my Dorton 350. They did a great job for not a bad price. Turnaround time wasn't bad either. They'll need to use some special tooling to get the booster and fastener secured back into the main body.
    • 1195
      • 86
      booster tool
      If you had one of these you could fix it yourself.
      • 84Dave
        • 915
        #62....... one of the best carb guys in the U.S. of A. is close to you. Bob Oliver of Competition Carbs. He worked over our Holley-type Pro-4 2/4-bbls for many years. www.competitioncarburetion.com .
        Ph: (775)331-5609
        5739 Tanberg Dr.
        Sun Valley, NV 89433
        -Dave-
