Mustang setup
  • drtlvr
    • Feb 2010
    • 233
    Mustang setup
    I've been running 53% left side weight for a while now but I'm thinking of changing to a higher %. Car handles good, I'm wondering if there's more speed there. All my weight is right around the right rear shock mount (about 200 pounds worth). If I move it to the left rear, I'm thinking maybe it will work the left side tires harder. Any opinions?
  • Dirtman29
    • 1690
    I moved my weight (50#) to the LR & went up on LR spring rate, made it much better (on corner exit). I was always loose off. RR was burning hot & LR was cold after 15 dry slick laps. After I made the change, car drove much better & LR had some heat in it.
    • drtlvr
      • Feb 2010
      • 233
      Yea my l/r is always cold and r/r is hot. But when I've tried to use more l/r spring, it wouldn't turn.
      • Dirtman29
        • 1690
        Maybe try a stiffer and/or taller RF spring. Help put more weight on the LR. I have a 750 RF spring now & it turns fine. Still a bit loose off but way better than it was.
