t 5 transmission swap
  • dmstang
    • Jan 2010
    • 31
    Can I put 5.0 t5 transmission into my 2.3 car? I'm interested in 1.99 ratio.
  • Milford Motorsports
    • Jun 2008
    • 285
    Pinto trans comes in 199.A lot less weight too.
    • Headhunter
      • 1338
      Yes, you just have to change the input shaft with a 4 cyl T5 shaft.
      • PitManArm
        • 138
        The input shafts are different length and the pilot diameter is different too. If you swap input shafts make sure they both have the same number of teeth, both on the gear and on the synchronizer.
        Aren't the V8 T5's about triple the price of a 4 cyl T5 though?
        Oval racing helps you unwind because you race counter clockwise.
        2007 and 2008 Ohsweken Speedway MiniStock Champion
        2007 and 2008 Merrittville Speedway 4 Cylinder Champion
        2009 Humberstone Speedway MiniStock All Canadian Champion
        • Headhunter
          • 1338
          Same except for lenght and pilot. This was just the standard T-5's not sure about the higher end ones though. I sold a couple of my 4 cyl T-5's to a 5.0 guy that liked the ratios better and it held up behind the mild built V-8 for years.
