thoughts on sohc engines.
  • steveshawjr
    • Jan 2008
    • 430
    just looking on your thoughts on the best sohc engine you can use in a mini.
    rules are
    engine - any 4cyl sohc
    must be carbed ( Holley 350)
    no port or polish
    stock size valves
    any stock rods (must have factory stamped logo & mach make)
    hyd/solid cam no lift rule (no rollers)
    flat top only
    no limit on head cut
    open headers.
    oem intakes with 1" carb adapter.
    what would you run with these rules
    62 mini mod
  • dannyracer6
    • 1063
    ford 2000 or 2300. cut the head to the bolt holes on the intake get a good solid cam kit for the track you plan to run on. Balance all the internals and put arp rod bolts on the rods.
    dr6 motorsports
    • 84Dave
      • 915
      What is the weight-to-cc Rule? Carb modifications permitted? Use a Schneider solid cam. They have (6) different lobe heights available for the valve lift of your choice. Balance the clutch, with the disc removed, once the crank is balanced. -84Dave-
      • raabbiitt
        • Oct 2009
        • 46
        oem intake with a carb pretty well leaves you with fords and old toyotas i think. can't think of a single ohc 16v that a came with a carb intake or one you could make work.
        • steveshawjr
          • Jan 2008
          • 430
          No weight per cc . 2150min weight. box stock holleys pv jet only mods. Same with stock carbs
          was looking at hondas online wonderd if the old carb intake could work
          oh btw tyotas got to weigh 2300 dont ask why lol because idk lol
          62 mini mod
          • raabbiitt
            • Oct 2009
            • 46
            a shot of a carb on an efi intake. an 8 valve vw but you can see the possibility if you can find a nice 16v with a flat intake.
