2300 Ranger Head
  • threed247
    • Oct 2012
    • 8
    2300 Ranger Head
    Anyone running a mid 80's round port ranger head on a stock 4 no porting? Just starting out I have a 89 mustang, Is the head on it ok to use
  • Milford Motorsports
    • Jun 2008
    • 285
    With the no porting rule you would be better off to get an oval or D port head from a mustang.Mill it to the intake bolt holes if allowed.Find a straight mustang intake(not the efi). With stock valves the straight intakes will give you better throttle response at lower to mid throttle.Stay away from the super size cams until you have perfected your cars set up and your driving style.Otherwise your engine and car will preform like a sick dog.
    • Headhunter
      • 1338
      The d-ports are good to use also use the lower efi intake if yoy have it. Post your motor rules before you go and cut it to the bolt holes to make sure you do not go over comression rules.
      • threed247
        • Oct 2012
        • 8
        The engine is an 87 efi , We have no compression rule but .450 lift hyd cam must use stock type cast pistons, 500 holley. What 's good duration numbers on a cam 3/8 mile dirt.
