best mustang carb intake ? and how to identify it
The D4 Oval Port intake in my opinin is the best,especially if you top it off with a 1.5" carb spacerNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
I've used the D4 oval port intake on an oval port head, and it was the best I've used.
But what's best to use with a D Port head?Last edited by 69ministock; 11-03-2012, 11:32 AM.
i honestly cant answer that...i ran a D-port head for part of a season with a E1 D-port intake and there was just no power there...put the D4 intake and my oval port head back on and had my power back...the heads were identical as far as cam,springs,valves,amount milled off,etc...
now im done racing for awhile...so im selling off everything
so if you need a good D4 intake(untouched casting)with lightweight 1.5" carb spacer...let me know!!!No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
will do Dan.No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
You can run a d port intake into an oval port, head, but you will have performance problems trying to run an oval intake into a d port head.dr6 motorsports
