Want to swap to rear disk brakes on my mustang 7.5. Has all stock brake stuff on it master cyl,prop valve will any of this have to be changed for the swap to work correctly
rear disk brakes?
No one has an idea or info on this. Its for a dirt car 3 wheel brakes maybe four if i use line cut off
I did a 7.5 rear disk brake conversion last year. Used thunderbird rotors, put longer studs in, and used metric calipers with weld on mounts. Works great and did not change anything else.
