Plugging cam tower oil holes question.
  • Doug_Guilds
    • 170
    I am wondering what is the reason for doing this? I know everyone does it and all but what is the exact purpose for it?
  • thegenerallee
    • Nov 2007
    • 41
    i not sure what you are saying in pluging the holes a lot of people weld a plate to the top of the towers for strength because the thin tops are the weakest point to the heads
    • A.Pinto
      • Aug 2007
      • 50
      I believe that some cam bearings are grooved on the non bearing side (makes installation easier, no oiling holes to line up). So if the hole on top of #2 and #3 aren't plugged, then a loss of oil pressure will result.
      It's always the crew chiefs fault.......
