through out bearing problem
  • dannyracer6
    • 1063
    I need an answer quick. I am trying to use a tilton single disc clutch on a QM flywheel. I am using a stock pinto type trans. The stock t/o bearing and it will not reach. I have not found out from anyone which bearing to use. can anyone shed some light on me for this.
    PM, answer or you can call me at 559 802 7006
    dr6 motorsports
  • let-r-eat
    • 2319
    If the old Chevy 250 6 cylinder bearing won't reach then if you have a torch and welder handy then cut the back off another stock bearing and tack weld it on the back of that one, move shifting fork to welded on section?
    BUCKLE UP NOW, YA HEAR?
    • dannyracer6
      • 1063
      Thanks, I will check out the old chevy one. But it puzzles me to think that they sell the clutch and there is not a thro out for it.
      dr6 motorsports
      • Gofast21
        • 32
        Speedway Motors sells a extented bearing for a Tilton/QM. Part# 605-498p. I use it with no problems. Sells for $79.99
        • dannyracer6
          • 1063
          Thanks, I will order it today.
          dr6 motorsports
