Bottom-end is stamped E89E-6015-AD. I'm guessing its out of an 88 and have no clue what model. Can anyone help?
decode bottom-end
If you are trying to determine if it is large or small journal then look at the back of the crank(non turbo application)if it is straight cut then it is large journal,if the last 1/4" of the crank is beveled then it is small journal.No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
