severly tight from center off. 3/8 asphalt 16 degree banking. springs lf 500 rf 600 lr 175 rr 150. wheel offset r 4" left side 2" right side. tire pressure 15 left side 18 right side. 1 1/2" stagger front and rear. no weight added. i have scaled car crossweight 50.4%, rear 47.5%, left side 56.1%. any help would be appreciated thank u.
severly tight mustang
1st...make sure car is square
2nd...make sure rear of car is not wider than the front
3rd...add more stagger(to rear)
4th...make sure swaybar is not preloaded,also check ALL suspension for binding...also check for bent balljoints.
What does car do on entry?No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
And has the front suspension been checked for bump-steer & Ackermann? Rules permitting, reduce those toe-inducing geometries as much as practical toward zero toe-steer when the wheel is turned left through a corner. Your cross percentage is pretty decent for the amount of rear percentage you have. -Dave-
Id swap your rear springs and definitely check the sway bar preload I never run mine loaded maybe 1/8" loose...
everything sounds good except right side psi is way to low
lefts 15
right front 23 to 25
right rear 20 to 30
stagger try closing up the front
try getting cross more around 52 if you start to get it goin good try preloading the bar u might just be saprized if theirs not much bankin
