Cam Id help
  • Betts83
    • 22
    Cam Id help
    I purchased a used head and can't find anything about the cam. The only numbers on the cam are e65774.
  • knight54
    • Aug 2012
    • 64
    Part Number/Work Order Number E65774Engine Application 2300 FORDGrind Number SAME AS E-0917ADVERTISED CAMSHAFT SPECIFICATIONS:INTAKE: Duration: 277º Lift: .398 Clearance Hot: .010EXHAUST: Duration: 277º Lift: .398 Clearance Hot: .010The specifications listed above are based on a rocker arm ratio of 1.66 IN1.66 EXRECOMMENDED VALVE SPRING INFORMATION:Part # Single Dual TripleApproximate spring pressure: valve closed: LBS.valve open: LBS. 18.0 BTDC 10.0 ATDC ABDC 42.0 50.0 BBDC camcardThe information below is for degreeing cam only. Correct only at .050" tappet lift.INTAKE Opens: 18.0 BTDCCloses: 42.0 ABDCEXHAUST Opens: 50.0 BBDCCloses: 10.0 ATDCLOBE SEPERATION 106ºDuration at .050" Intake: 240Exhaust: 240LOBE LIFT Intake: .240Exhaust: .240If using "Lobe Center" method of degreeing, cam should be installed on an intake centerline of: 102ºNOTES:B-625 INTAKE AND EXHAUST7/5/07Cams damaged by excessive spring pressure, over shimming, valve train bind or retainers contacting the guides are void from warranty. Refer to the "Important Camshaft and Lift Information" booklet included with each new Crower camshaft to avoid any break-in problems.
