350 holley help
  • drtlvr
    • Feb 2010
    • 233
    350 holley help
    I've been having a unique problem with heating all this year. This is a 2300 5.7 rods, wisecos, head cut to intake bolt holes, 500 lift solid cam, 350 holley and tri-y header. I've been running the same carb for years and has been running flawless. All this year it's been running lean and the motor gets 240 at the end of the race. The carb is a 7448 with a good metering block with power valve restrictors. Usualy ran 64 jets, now I'm at 68 and it loads up some off idle where I went up on jets. 4.5 power valve. The carb runs perfect other than lean. The tailpipe comes out the door. For the past few years it's been blacking the side of the car and no overheating. Now it's chalky white and gets hot. It ran cool last year and nothings changed that I know of.
  • 7uptruckracer
    I wouldn't lean towards carb. I've always run alot more jet like 74 with that setup, 25 squirters, white pump cam, 7psi. 3.5 power valve. I'd lead towards timing, or some kind of cylinder wall crack or head crack, or radiator problem.
    • drtlvr
      • Feb 2010
      • 233
      OK...so I've went up to 74 jets and when the power valve opens it'll barely run until I get wide open on the track and my rpms have came back up to 8500 where it was leveling out at 7500. Should I just block the power valve and go up on the jets? What happens to a carb when it runs rich with 64 jets 4 years and all of a sudden it goes lean and end up going 10 sizes bigger on the jets? Everything is the same as the past years. Cam, head, new springs, bottom end. It runs perfect just too lean.
      • return to dirt
        • 1008
        i would look for a problem some place else. i run about 64 jets on my 350. 74 or 75 is too big for a 350. that's what i run in my 500s. recheck your ign timing and cam timing.
        olin
        • drtlvr
          • Feb 2010
          • 233
          I'm thinking something's happened in the metering block. We freshened up an old Earl Parker 500 we used to run. If it runs good I know it's the carb. I agree with you on the jets, I've never had to go that high. We've checked all over this car for vacuum leaks, timing (cam and ign), fuel, etc....
          • FlaviaBlackwelder
            • Jul 2013
            • 12
            But i think it is great..
            Youtube Downloader for Android
            • millerlt3
              • 96
              It may be fuel delivery problem check the float level at idle but make sure there is not a problem with the float, needle and seat if its sticking as the fuel is being used it wont draw fuel into the carb also try a different fuel pump to see if that fixes it
              Miller
              • drtlvr
                • Feb 2010
                • 233
                Well I tried a 500 and didn't like it so went back to the 350 for the feature. 2.5 powervalve, 69 jets, still lean. New fuel pump going on it before next week.
                • drtlvr
                  • Feb 2010
                  • 233
                  New fuel pump fixed my problem. Thanks for the help
                  • checkeredflag2006
                    • Jan 2009
                    • 212
                    Its little late on this post but on my 350 we run a 35pv 76-78 jets
                    • checkeredflag2006
                      • Jan 2009
                      • 212
                      What fuel pump are you running kinda having same problem
                      • drtlvr
                        • Feb 2010
                        • 233
                        stock ranger. Changed it and went back to original jets. I had 75 jets in it at one time and could barely get through the pits where it was loading up. She's right now
                        • Aden8100
                          • Sep 2013
                          • 4
                          I am also facing the same problem with my car. I read out interesting and informative ideas. This will be sure helpful for me. thanks everyone...
                          Vehicle Access Conversions
                          • checkeredflag2006
                            • Jan 2009
                            • 212
                            New pump fixed mine to!!
                            • dave41
                              • 208
                              air flow
                              how can you get that much air and fuel mixture out of 350 cfm's
