Bought a short block and I'm needing to freshen it up there are no numbers or markings on the pistons. Is there anyway to find out what they are? Thanks
Piston help
Can you take a picture of the bottom? Looks like they are an older style stock rod length pistons. Maybe Icon or Probe from the looks of that picture...Originally posted by ministockrcr16 View PostBought a short block and I'm needing to freshen it up there are no numbers or markings on the pistons. Is there anyway to find out what they are? Thanks
Bottoms no casting marks do I am guessing forgedAttached Files
i am thinking there wiseco need to order rings i have noticed the space between the oil rings are taller than my other wisecos needing rings and i want to be able to get the right ones
they look just like a set of wiscos i have here that i bought in 2002 except mine are for a 5.7 rod. should use a standard "C" set of rings.
olin
