question on blowing head gaskets
  • pilotracer
    • 160
    My question is I have to race emg m0tors a 2.5 and a 2.7 compression about 230 they both after about three racea on a head gasket blow preaaure in to the water system and the hoses swell run it about five races change it good till it starts again on both motors any ideas do I need a special gasket for there motors?
  • pilotracer
    • 160
    Tried a few diff heada and nothing even new block on the 27 and havent ran it since cause I got sick of changing em
    • Big E tech
      • 104
      We o-ring the deck on all our hi-po engines, and NEVER have to worry about headgasket failures. We use the standard Felpro 8993PT-1 cheepie headgasket too!
      • 7uptruckracer
        We had a problem with the Cometic Head Gaskets doing that after a few heat cycles we rechecked the head stud/nut torque and that seems to fix it maybe coincidence?
        • pilotracer
          • 160
          Tryed new head studds I just change em but it gets old changing gaskets amd studs every five races
          • miniman69
            • 58
            when I was racing we had HG issues my friend hooked me up with his motor guy he had me back the timing down and use a better grade of fule [detonating] also if you are putting the same head back on with out checking it and not with a straight edge, what are you taking the bolts to and what is your sequence is the gasket blowing in the same place he started building my motors and we never had any issues after that we were down to 40cc and never blew one after the changes he still does some motors I think he is in your neck of the woods he had a black car #15 that thing had a hell of a motor for a 2.5
            • pilotracer
              • 160
              New studs every time and diff gaskets and bramds and the right seq and two totally diff motors from diff people amd four diff heads all do same thing ? Not high enough octane or to high of timing but standdard 34
              • let-r-eat
                • 2319
                What fuel? What size head chamber? 34 shouldn't be too excessive on a steel headed engine.
                BUCKLE UP NOW, YA HEAR?
                • return to dirt
                  • 1008
                  are you shortening the alignment sleeves and adding an extra washer on your studs?
                  olin
                  • pilotracer
                    • 160
                    thats a idea maybe I need new alingment pins and short em and yes they had washers but idk if they was shorted or that could be the prob to long ?
                    • pilotracer
                      • 160
                      rrad
                      I run 110 klotz
                      • car62
                        • 1579
                        how much is milled off your heads?...since you run racing fuel it must be quite a bit,if you havent shortened the locator sleeves then yes it will blow head gaskets...as car as timing,we run 38 degrees with 5.7 rods
                        www.raceidaho.com
                        • pilotracer
                          • 160
                          Yes there may be 2 thousands left before intake threads and ok anyone know where u can get new alingment pins and what spec ahould they cut down too
                          • Big E tech
                            • 104
                            Esslinger makes/ sells them, or you can just shorten the ones you already have...
                            • camarofever
                              • Apr 2013
                              • 85
                              can anyone tell me the difference between the 8993PT-1 and 1035 felpro head gaskets? also where can i get my hands on locator sleeves? A motor i bought didnt have any
