Rule states.....Solid Cam with maximum .470" valve lift. Cast head with no port work allowed and head is 55cc with 10:1 compression engine. I run ford 2300 on a fast low banked 3/8 mile asphalt track turning max around 7500 rpm. Looking for competitive cam or at least maybe some good specs I should be looking for on a cam to fit my needs. Thanks in advance!
Solid Cam Ideas
You'd be doing good to go with the Esslinger 2270 cam. It's 258@ .050" and comes in at .468" lift on a 107LSA. Over the years, that cam has won more races in Mini-Stock than any other cam...Originally posted by 20MS View PostRule states.....Solid Cam with maximum .470" valve lift. Cast head with no port work allowed and head is 55cc with 10:1 compression engine. I run ford 2300 on a fast low banked 3/8 mile asphalt track turning max around 7500 rpm. Looking for competitive cam or at least maybe some good specs I should be looking for on a cam to fit my needs. Thanks in advance!
On a side note, is there a reason you're only using a 55cc chamber? Are you not allowed to get the head down to 39-42cc? The compression increase, as well as installing the cam around 4-6deg. advanced would really perk that thing up on re-starts...
do you have to run a solid cam? with that lift and rpm a hyd. head would work and be cheaper to build and less maintenance.
olin
