We have to run a street tread tire no racing tires. What is the softest compound out there and what would you recommend? thanks.
Tire recommendations for ford mustang 4 cyl. ?
The softest DOT tire I have seen recently is around 380. Im using kumho tires with a 740 treadwear rating & those have excellent grip. Look at tread design & tread width more than the treadwear rating (mainly for rear tires), I run good used tires from the boneyard on the front.Originally posted by ImaCheater View PostWe have to run a street tread tire no racing tires. What is the softest compound out there and what would you recommend? thanks.
Some yokohamas are 50, falken azenis are 200No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
