Brake rotors
  • Creppers
    • Aug 2009
    • 49
    Brake rotors
    I am running a 93 mustang but the person that had it before me put the smaller brake rotors on it can someone tell me what year ect I need to ask for to get the smaller pads
    Thanks
  • car62
    • 1579
    for sure 1979-1984 LX 2.3 non turbo
    www.raceidaho.com
    • Creppers
      • Aug 2009
      • 49
      yea thats what year I tried I Have looked at a lot of different years and they all are close but are to wide the pad it self is 1 1/14 wide that Im looking for
      • return to dirt
        • 1008
        1, did they use the correct knuckles for the small rotors?
        2, did they use the correct calipers for the small rotors?
        the info car62 gave you is correct. 78-83 fairmont pads should also work.
        olin
        • car62
          • 1579
          easy way to tell is if the calipers are held on by allen or torx,they are the large spindles,if it is an 11mm bolt they are the small spindles
          www.raceidaho.com
          • Creppers
            • Aug 2009
            • 49
            Thanks for all the help I know calipers used a bolt I might try getting new calipers and brakes even might have to start over with it all
            Thanks again
