Valve Spring preasure recommendations.
  • Doug_Guilds
    • 170
    I just bought a head and it has a 528/538 solid lifter flat tappet cam in it. what seat preasure should i be looking for in springs? Does 120 ish sound right? I looked up the info for the cam and it's a Race Engineering cam but no recommendations on springs. Also who sells the best springs?
    Forgot to add that this is for a 2.3 Ford.
  • let-r-eat
    • 2319
    Crane 99884 is a good little spring for that installed at 1.550. That's around 127 or 28 on the seat.
    BUCKLE UP NOW, YA HEAR?
    • Jb35
      • Jan 2013
      • 37
      I would shoot for 110 pounds at seat. That should be safe to 8000 rpms I think. 120 is a little much Iwould think. I've run as low as 100 with a cam close to that size up to 8300 rpms. The more pressure from your springs the more horsepower your killing. I get springs from crower most of the time.
      • Doug_Guilds
        • 170
        Thanks for the info so far! One thing I am wondering also is, what can we use to test seat pressure on the 2.3 ohc? I see a lot of pressure testers but they don't appear to be usable on an over head cam set up.
        • let-r-eat
          • 2319
          romac tester and a height mic during installation?I don't test any while they are installed.
          • J.D. Laramee
            • Nov 2007
            • 111
            If, That cam and rockers have been run together, previously broken in, 130 on the seat is good. I get most of my springs from Howards or Schneider. 110is not enought pressure for that cam, It has a pretty aggressive lobe. I still set up heads at 130-145 on the seat, and flat tappet,Hyd. or solid.,Joe
            WORLDS Quickest and Fastest 4cyl. street pinto!
            RT.... .0031
            1/8TH. 5.41 @ 130.44 mph
            1/4 8.43 @ 161.92 mph
            175ci C&S specialties Blow thru carb, , Arca head, Fuelab
            World Quickest and fastest 4cyl. Race pinto!
            1/8th. 5.06 @ 137.82
            1/4 8.02 @ 164
            185ci - C&S specialties Blow thru 4bbl. carb,
            • 84Dave
              • 915
              PAC beehive spring. I've used them for years on my paved oval engines. Have never failed one. And PAC will nitride them, which adds life. www.RacingSprings.com . -Dave-
