Anyone know where to get Escort Caliper Brackets for the Ford 7.5 rearend? I have tried to get ahold of FLYNBRYN but no luck.
www.raceidaho.comTags: None
no,these are weld on brackets that you weld to the rearend housingNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
ok...any brake gurus out there that can point me in the right direction?
1986 fox body mustang with manual brake adaper in firewall,Wilwood Tandem Master 7/8 bore, part number 260-9439...front brakes are all stock with new calipers and cross drilled and slotted rotors,all new metal lines to wilwood proportioning valve right next to driver,then back to new 1989 escort front calipers on escort cross drilled and slotted rotors.
we can get full front brakes,but no rear brakes,we have replaced all lines, all fittings,everything is inverted flare fittings to double flare lines,the escort calipers originally took a banjo fitting,so re-tapped them to a 3/8-24 and screwed in a female inverted flare, then ran the rear lines into those,no matter what we try,we cannot get rear brakes,we are over a month into this battle and so far have went through over 2 gallons of brake fluid,used the old fashioned method of someone pumping brakes,then crack bleeder,also used a vacuum pump,then an air powered vacuum pump,then a phoenix brake injection system...have had the same results with 3 different stock masters,and now this wilwood master,also eliminated the factory distribution block and residual valve,so the primary line from master goes to a T which then goes to RF and LF brakes,the rear(secondary) then goes to wilwood proportioning valve then to rearend,then out to escort calipers,have tried bypassing proportioning valve with same results,also tried switching the rears to the front to see if master was the issue,no such luck...PLEASE HELP..i have been pulling my hair out over this issue.
Sincerely, Going Bald in IdahoLast edited by car62; 04-24-2014, 01:05 AM.No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
Have you tried using a brake pressure gauge to determine if there is the appropiate pressure at the rear brakes? It may help point you in the right direction. Even though the front brakes seem to be working there may be something in the line going to the rear brakes preventing them from getting the correct pressure. It is worth the time to help isolate the problem. Someone near you must have a brake bias gauge setup.
yes there is fluid at the rear calpers,bleeder valve is the highest point on the rears,master sits levelNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
If your absolutely sure you have removed all air, and sounds like you are, then I am going to give you the same advice I gave you on your other thread about this. Get the residual pressure valve from my earlier post. Place it at the master cylinder. I know what wildwood and the other "experts" say. I have had this same issue before and little valve is like magic.
you can also install a pressure gauge in the bleed hole and see if you are getting the proper pressure. If you have normal pressure look at the calipers. If you are using used parts that you don't know the history of, make sure the pistons move and are not frozen in the bore.
so put a 2psi valve right at the master for the rear brakes? or should i get 2 of them and do it at both the front and rear?Originally posted by mtbailey View PostIf your absolutely sure you have removed all air, and sounds like you are, then I am going to give you the same advice I gave you on your other thread about this. Get the residual pressure valve from my earlier post. Place it at the master cylinder. I know what wildwood and the other "experts" say. I have had this same issue before and little valve is like magic.
you can also install a pressure gauge in the bleed hole and see if you are getting the proper pressure. If you have normal pressure look at the calipers. If you are using used parts that you don't know the history of, make sure the pistons move and are not frozen in the bore.No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
oh sorry,yes EVERYTHING is brand newNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
