Driveshaft Question
  • razorbackrob
    • 39
    Driveshaft Question
    Needing to buy a drive shaft for my mustang ministock, any suggestions?
  • Jb35
    • Jan 2013
    • 37
    Stock driveshafts work fine. Not a lot to gain by a high dollar light weight job. If ur motor is set back you might have to get it shortned. Weld a loop or 2 around it to keep it from dropping down to the track.
    • 84Dave
      • 915
      I would agree with Jb35. And most importantly, particularly if you have it modified even slightly, or have the U-joints replaced, have the finished product BALANCED before use. -Dave-
      • empiretrucks
        • Jan 2011
        • 29
        Some rangers came with a stock aluminum driveshaft. If you can use one, it would save you a bunch of rotating weight.
        • car62
          • 1579
          Aerostar vans had aluminum drivelines...i use a maverick or comet driveline and slide the engine back
          www.raceidaho.com
          • Dirtman29
            • 1690
            A friend of mine has an aerostar shaft, whatever one he got is WAY too long for a mustang. and not any lighter IMO.
            • return to dirt
              • 1008
              with the small diameter the rotating weight is not that big of a deal. a lighter wheel will be of more benefit.
              olin
