Found a nice one from a '93 cheap in local boneyard, are they any good for racing or should I pass on it? Any info appreciated.
OEM ranger header
The cast iron tri y headers flows better than any other factory manifold including the Ranger. The Ranger manifold was never designed to be a header. It has lots of bumps and other flow restricting problems. Just look into it and you will see. It's only advantage is it is lighter than the tri y.
