easy oil pan question
  • empiretrucks
    • Jan 2011
    • 29
    Will an oil pan and pump from a 99 ranger fit a 1978 block? Ill save myself the step of pulling the pan off my backup motor to check if you guys know quick. Thanks!
  • dannyracer6
    • 1063
    I believe the oil pump in the 99 ranger has a different pump which runs off the aux drive, not a dist drive. In fact the 99 does not have a place for a distributor. It is all elect. The pan is aluminum and I don't think it will work either unless you change the rear main cap and it uses the ribbon oil pan gasket.
    dr6 motorsports
    • return to dirt
      • 1008
      the aluminum pan will crack easy.
      olin
      • empiretrucks
        • Jan 2011
        • 29
        Thanks guys. Ill go find a mustang rear sump pan and pump.
