Anyone have good luck cutting pistons for larger valves?Thanks
Cutting pistons
I would take them to a shop that has a milling machine and piston vice and have them do it that way you would be more accurate for depth without to much work. Also you will want to have .060 clearance radially so you would have to use a bigger diameter valve than the one you are going to run.
